Date:    5-17-2014
Number of Hours:    2.00
Brief Description:    Re-check upper plugs
I needed to check the upper plugs. They are harder to get to than the lower plugs, so I'd been putting it off.
I removed the side baffles, removed the plugs, rechecked/reset their gaps, added anti-sieze to the threads, and reinstalled.
I checked the plug connectors to make sure the conductor was properly installed, which they were.
Everything was reinstalled.
I took the opportunity to add more zip ties to stabilize everything and secure to the engine mount wherever possible.
