5-5-2014 |
2.00 |
Reinstalled new EGT #4 probe |
I received a new EGT probe from MGL today (for free!), as the previous one wasn't working. I tested this new one before installing and it worked (hooked it up to the RDAC, turned on the EFIS, and put a lighter under the probe). Installed the probe in the exhaust. Again, the location would hit the cowl, so I bent over the probe with a vice and small sledge hammer. Routed the wire through the baffle, over the engine, and down to the RDAC. Barely enough wire to get there. Re-zip tied the wire bundles. Tested everything and it works. |
