4-4-2014 |
2.00 |
Finish fuel system |
A. Installed the replacement spark plug (the one I broke last time by over torquing. B. For the most part I finished the fuel system tonight: - Installed new clear fuel line for the sight tube - Added fuel 1 gallon at a time. By shining a flashlight up at the underside of the fuel tank (photo 1) I could mark the tank at each increment (photo 2). - At 5 gallons the bottom of the sight tube had visible fuel so I marked that on the tube (photo 3). - I'll make cleaner lines with a straight edge later, and put numbers next to each. THE ENGINE IS READY TO START! |
