Date:    10-18-2013
Number of Hours:    1.00
Brief Description:    Another hour of sanding
Spent another hour sanding the filler from last night. I had to add a few very small dabs tonight.
I still need to fasten the lower cowl to the fuselage, at the underside. There are two piano hinges that do the job, but getting the holes aligned is the tricky part.
After that I should be ready to start prime paint. But let's not get ahead of ourselves...
