10-17-2013 |
1.00 |
Adding more filler |
Added filler to the remaining low spots in the upper and lower cowl, and the first whell pant. Then installed a 5/8" ID hose on the 5/8" aluminum tube from the oil breather. I added a 5/8" to 1/2' reducer, and at 1/2" hose will be attached to that. That hose will penetrate the rear baffle and go to the inlet of the air/oil separator. |
