Date:    10-14-2013
Number of Hours:    1.00
Brief Description:    Sanding filler
Sanded the filler. Started with an oscillating sander, then moved to hand sanding. The upper cowl still has a couple of low spots. The lower cowl has a lot of low spots, but fairly small. The wheel pant also has some of the seam that did not fill completely.
