Date:    9-27-2013
Number of Hours:    1.50
Brief Description:    Oil filler door
- By watching the shadow of my finger through the cowl (looking through the cooling inlet) I marked the location approximately over the oil filler.
- I drilled a pilot hole (photo 1) to verify that the filler was centered below.
- Then I used the Dremel to cut out the flat-sided opening (photo 2).
- After sanding all the edges I put it over the engine and it aligned perfectly.
