Date:    9-21-2013
Number of Hours:    2.50
Brief Description:    Oil Cooler Baffles - Done
Riveted all the seals in place, then test installed the cowl. Everything seemed to fit well, so we'll make it permanent!
Now I can go on to finish the upper cowl.
Also started a little fiberglass repair at the lower left of the cowl, In photo 3 you can see a strip of fiberglass that I epoxied on. Tomorrow I'll add some glass to finish it off.
