Date:    9-12-2013
Number of Hours:    0.00
Brief Description:    Cowl + EGT probe, 2 of 2
Next I used the Dremel cutoff wheel to cut out the oil cooler opening, which you can see in both photos. I then used a coarse file to file to the final outline (not shown).
Photo 2 shows the oil cooler rough cut, and the cowl inlets with the measured sections cut away.
