Date:    8-13-2013
Number of Hours:    0.50
Brief Description:    Last layer of fiberglass
Added the last strip/layer of fiberglass to the upper middle of the cowl.
I have been using peel-ply after laying down the fiberglass, and it REALLY makes the final result smooth and finished! After puting on the peel-ply you use a scraper (a simple wood popsicle stick will do) push it down, and to squeeze out the extra resin to the sides. When you remove the peel-ply the next day it's all nice and smooth.
