4-13-2013 |
1.75 |
Completer rear and side baffles |
- Deburred rear baffle and riveted. - Laid out and finished the left baffle. - Put the upper cowls on to check their fit. The cowl is very tight agains the cowl. Maybe too tight? Though it seems very important for a VW to make sure no air escapes the baffles, so maybe tight is good. - With both upper cowls on I cleco'd them down the centerline again to test overall fit. |
