4-9-2013 |
1.75 |
Attaching baffle material |
- I took 1/8" off the metal baffle, per my measurements last night. Then deburred the edges. - Trimmed the aluminum strap that will hold the baffle seal, and drilled pilot holes every 1.5" or so. - Clamped the strap to the baffle and drilled the pilot holes through, using Clecos as I went (photo 1). - Put the baffle seal in between the baffle and strap, and drilled through all 3. Cleco'd, then updrilled the whole assembly at once (photo 2). - Took it apart and deburred everything. - Riveted the 3 pieces together. - Also added one of the support angles (photo 3). I was able to mark the hole locations while the baffle was still on the engine. But the 2nd angle is under the intake manifold, and I have not found a way to get any kind of marking device in there to mark the hole locations. |
