4-3-2013 |
2.00 |
Drill baffles |
- While still on the engine, drilled pilot holes through the baffle pieces and cleco'd them together. - Removed baffles and trimmed a few more areas. - Used a fly cutter to cut out the hole in the rear baffle, for the cabin heat pressurized air. I have a hose fitting that will get riveted to the back side of the baffle. - Drilled the 4 mounting holes for the aforementioned hose fitting. |
