3-20-2013 |
1.25 |
Continue fitting left cowl |
- Did some more trimming of the left cowl to get it to fit with the fuselage and with the right cowl half. - Then cut the cowl horizontally as I did for the right cowl. In photo 3 you can see the 4-way split in the cowl. Once I get everything fitted I'll fasten the right/left halves together and then fiberglass them into a single bottom cowl and a single top cowl Tomorrow I will begin adding the hinge half to the lower and upper cowl pieces. |
