2-11-2013 |
1.00 |
Engine baffles |
Bent the rear engine baffle per the plans (four 10-degree bends). Then test fit. The upper spark plug wires and the air intake pipes must be removed to continue. After doing that I slid the rear baffle down as far as it will go before trimming is required. I think I'll make a cardboard template of the baffle and use THAT to make my measurements and cuts. When complete, then I can transfer to the aluminum baffles. |
