2-4-2013 |
2.00 |
Oil Cooler Baffle |
- Enlarged the hole in the oil cooler baffle to also expose the fitting where the oil return is to go. - Cut out a large slot in the oil cooler baffle, with an integral fence at the back side, to deflect air down across the oil cooler (oil cooler not in photo #1). - Installed the knob/cable for the cabin heat box. In photos 2 and 3 the knob is pulled out, and the flapper valve open, to allow warm air into the cabin. |
