1-26-2013 |
1.25 |
Exhaust + electrics |
Temporarily installed the exhaust pipes. Next I need to put on the intake pipes. Both are on only temporarily until all adjustments are made for location and interference. Photo #3 is where I cut a section out of the 10awg wire from the relay to the battery post. I then put in a 25amp fuse (it's in the black box there). This will save the voltage regulator or the battery from a runaway charging system. |
