1-8-2013 |
2.00 |
More wiring |
1. Did more wiring tonight... wire runs + connectors. 2. With input from other builders I finally realized that the AeroVee starter has its own starter solenoid (photo #2), so I don't need the one on the firewall! So I took it off (photo #1). 3. I also attached the power wires from the avionics (photo #3) terminal block. I'm waiting for some more wire connectors so I can finish up the wiring. In the meantime I continue to update my wiring diagram, and my panel layout. |
