11-10-2012 |
0.00 |
Flywheel & accessory plate |
Photo 1 shows the flywheel gland nut set in place. 4. Installed the magnetrons (x2) in the accessory plate, then 5. Installed the accessory plate on the back of the engine. 6. Next I needed to set the gap between the magnetrons and the flywheel magnet. Unfortunately I only have down to a 7mm wrench, and the nuts (hidden behind the accessory plate) are tiny; something like 3mm or 4mm. So I was not able to set the spacing. I will need to go out and see if I can find a teeny-tiny wrench. Vice grips and needlenose pliers can't get up inside there. |
