Date:    3-28-2012
Number of Hours:    1.00
Brief Description:    Overflow pan
- Applied the last coat of clear coat to the wing tip.
- Added a stainless steel patch over the hole that the overflow tube comes out of. After it dries I'll add fire caulk. Photo #2.
- Installed a bead of fuel proof sealant (unfortunately it's black) at the gaps around the overflow pan, including around the filler neck (photo #3).
