Date:    12-10-2011
Number of Hours:    3.25
Brief Description:    Cross tie plates + deburring
- Drilled and installed the cross tie plates/anchors. Had to remove the glare shield and instrument panel to do it.
- Removed all the recent parts relating to the glare shield and instrument panel to deburr them all. LOTS of holes to debur.
- Removed the lower skin so I can access under the glare shield and under the seat & spar tunnel structures.
- Put everything back together temporarily so I can install the 3 sheet aluminum angles that hold the glare shield to the upper firewall. DAMN, I'm going to have to drill stainless again!
