Date:    12-9-2011
Number of Hours:    2.50
Brief Description:    Instrument panel & glare shield
Continued to work on the panel and glare shield. When I say "installed" I just mean I located and drilled. I will cleco later.
- Installed the corner brackets at each end of the panel
- Installed F07-06 cross tie plates to tie the panel cross tie to the fuselage longerons
- Installed the panel cross tie, except have not yet drilled the holes to joint the cross brace to F07-06 (have to do that from above, with the glare shield removed).
- Updrilled all the holes along the edges of the glare shield
- Updrilled all the holes having to do with the panel and its supports
More photos on the next three pages...
