12-4-2011 |
2.25 |
Glare shield & panel |
Spent some time looking over the F06 drawing sheet. Went to a couple of other Sonex web sites to see in what order others had done this sheet. - Test fit the glare shield in place (photo #1). - SAT IN THE THING FOR THE FIRST TIME! Momentous occassion! Started building my panel. I don't have any instruments yet, but I have the layout to scale. Per photo #2 I plan to make the two ends fixed (riveted) in place, and have the center section held in place top-and-bottom with hinges (like the seat and cowl), and the vertical edges with some nut plates and screws. - So I started building the removeable center section, which you can see in photo #3. The partial hinge half at the bottom is just for reference. |
