Date:    10-11-2011
Number of Hours:    3.00
Brief Description:    Lower firewall
- Finished pilot drilling into the lower longerons of the forward fuselage sides.
- Laid out, cut, bent and drilled lower stainless steel firewall
- Loosely fitted the firewall. It needs some trimming at the corners (square corners don't fit in radiused inside corners (photo #3), and some minor trimming where it butts the cowl hinges.
