Date:    10-8-2011
Number of Hours:    2.00
Brief Description:    Trim/Flap Assembly
Finished the Trim/Flap assembly.
- Clamped all the pieces in place.
- Pilot drilled then updrilled. Used my 12" bits to get straight holes and to get to the holes under the detent angle (right side of photo #2).
- Deburred.
- Installed the plastic washers and screw to hold the trim lever in place
This sheet says to rivet in place (or at least it doesn't say "not" to). But if I do that then the rear angle will no longer be removealbe. It needs to be removeable for wing rigging. So I'll leave this assembly simply cleco'd for now.
