8-14-2011 |
1.50 |
Aft fuselage, lower skin |
- Used masking tape to hold the fuselage sides against the edges of the lower skin. - Pilot drilled and cleco'd the lower skin to the longerons and the forward channel. Earlier I took pictures of how I laid out the aft fuselage, but didn't really describe it. - My work bench is exactly 40" wide (same width as forward end of the aft fuselage tail cone). - So I drew a centerline down my work bench and centered the forward end of the tail cone (easy, since I just aligned with the outside edges of the 40" workbench). - At the aft end I screwed an angle to the work bench, to use as a "backstop" to push the fuselage against. - There is a dimension per the plans, for the distance of the two side skins from one another. - At the angle, on either side of the centerline, I marked off that distance. - Now I set two small nails on those two marks (barely visible in photo #2). - Now I could place the two skins against the inside faces of the two nails, giving me a continuous and repeatable way to maintain that distance at the aft end of the tail cone. Works like a charm. |
