7-7-2011 |
2.00 |
RIGHT aft fuselage brackets |
Installed the upper and lower fuselage brackets. The corners of each part are chamfered to meet together within the longeron angle. On the top brackets I needed to shave off a lot more material from my chamfers, which I did with a coarse file, fine file, and the Scotch Brite wheel. On the lower brackets I needed to shave some material, but not as much as on the top brackets. More pictures on the next page... I hit 1,200 hours tonight. |
