6-20-2011 |
2.50 |
RIGHT flap construction |
- Set the rest of the ribs in place, pilot drilled, and then updrilled, on 2 of 3 faces. - Deburred and reassembled. - Flipped flap over, closed skin over ribs (photo #2), then pilot drilled and updrilled. - Once again used one of my metal straight edges for the hinge offset (I cleco'd the skin to the work table to hold it flat), per photo #3. - Once again used double-sided tape to hold the hing in place while drilling. Got about a dozen holes drilled to hold the hinge in place. |
