6-19-2011 |
2.50 |
RIGHT flap construction |
- Laid out for all the holes in the skins. - Cut the notches out of the inboard end. As with the ailerons I used a Dremel tool to cut at the bends, then the shears to cut everything else. - Pilot drilled all the holes in the skin. - Drew centering lines on all the rib flanges then aligned and pilot drilled 2 of the 4 ribs. |
