5-3-2011 |
0.00 |
LEFT wing walk & root doubler |
- In photo #1 you can see the doubler trapped between the skin and the rib. - In photo #2 you can see how I traced every hole from the skings to the doubler. - I then removed the wing walk/doubler and pilot drilled all the holes I marked in red. - Photo #3 is the result, with all pilot holes drilled. |
