5-2-2011 |
1.50 |
LEFT wingtip light pod |
Worked to finish the installation of the wingtip light pod. - With the pod taped down, drilled 4 holes thru pod and into wingtip - Installed 4 nut plates. I was brain-dead when I intsalled the forward one (photo #2), orienting it horizontally instead of vertically. Fortunately the pod (green line) covered the forward rivet, but it was close. - The hole in the wing tip is for the light's wiring ======= Then took off the leading edge skin and began the process of locating the wing walk again, so I can next bend the root doubler around the leading edge of the rib. |
