Date:    4-30-2011
Number of Hours:    3.00
Brief Description:    LEFT wingtip install
Installed the wing tip (actually it's called the "tip rib", but it's not really much of a rib).
- Held the tip in place with blue painter's tape.
- Pilot drilled all the holes.
- Updrilled all the holes to final size (according to the Sonex instructions, no need to countersink the rivets on the leading edge skin.
- Located and taped on the wingtip light pod (they are GuagePods, made for the Sonex).
http://www.gaugepods.com/aircraft.html
- Put the tip ribs side by side and located the RIGHT wing tip pod to match the left wing (photo #3).
- Drilled a hole in the wing tip for the wires for the lights.
- Turned the wing over and deburred all the wingtip holes.
- Then began planning the layout of the wing walk.
