4-26-2011 |
1.75 |
LEFT wing hinges |
- Cut and located the flap and aileron hinges. - As on the other wing, I used double-sided carpet tape to hold the hinges in place while checking for and adjusting the hinges to be perfectly straight. - Then the hinges were clamped into place for pilot drilling - All the pilot holes were completed in the flap hinge, and clecos were installed as I went along. Then all the holes were up-drilled to size. - The aileron hinge was taped and clamped, but not drilled. |
