4-4-2011 |
0.00 |
Install RIGHT leading edge skin |
After securing the leading edge skin down the length of the spar with clecos, I started securing to the ribs, starting at the center rib. I worked toward the nose, then moved over to either side of that rib line, to work on the other ribs (see photo #1). |
