1-12-2011 |
1.25 |
Pitot/Static attach plate |
I designed and made an attachment plate for the Aircraft Spruce pitot/static assembly. This may or may not be the way others have done it. - The plate has a large hole for the small round collar of the assembly to fit into. - The plate gets fastened to the large collar with bolts and lock nuts (not shown). - The plate has 4 anchor nuts on the back side, set with small countersunk rivets. - When inserted thru the wing skin, the plate will be held in place (inside the wing) with 4 countersunk screws, into the anchor nuts. |
