Date:    1-1-2011
Number of Hours:    2.50
Brief Description:    Polished another wing skin
Polished the second to last wing skin. Had to first remove the paper pattern with WD-40, then remove the protective plastic from the other face.
Prepped the last wing skin that needs to be polished. Had to first remove the paper pattern with WD-40, then remove the protective plastic from the other face.
