11-13-2010 |
3.00 |
Wing Skins |
- Finished making and installing a hold-down plate for the landing light transformer. Per the first photo there is an aluminum plate, ss screws, lock washers, anchor nuts and LocTite, all holding down the transformer. It ain't goin' nowhere. - Continued working on W19-01 L. It takes a LONG time to lay out the curves at each end, and then to lay out all 430 or so holes! It's all cut out, and I started the holes. Then edges will need to be deburred, along with the holes. - Also finished pulling the wire for the position lights in the left wing. Will be away on business for the next few days, so won't be able to do any work :-( |
