6-27-2010 |
3.75 |
Drilled nearly every pilot hole in spar/caps |
Drilled nearly all the remaining pilot holes through the webs and through the top and bottom spar caps, as well as most of the angles. I find drilling 3/32" pilot holes first makes for more accurate up-sized holes, and the up-sized holes drill through like butter. Damn, there are a lot of holes! My right arm and shoulder can tell you that. With this work I topped 700 hours (702.75, actually) on the project. |
