6-1-2010 |
1.00 |
Left main spar web - transfer hole locations |
The left spar pieces are stacked slightly differently than the right wing spar. On the left spar, the root end of the long pieces, W10-01 (which has all the pilot holes drilled in it), is sandwiched below W10-05. In that position the holes at the top and bottom of W10-01 cannot be used to locate and drill through all 4 layers of web at once. So I cleco'd W10-01 and W10-05 together so that I could transfer the hole locations from W10-01 to the face of -05 that will be exposed when the spar webs are stacked and the spar caps are positioned. I also located and drilled the holes for the wing tie-down angle, which I had forgotten to do last night. |
