5-15-2010 |
2.00 |
Finished the wing attach blocks W11-02/-06 |
I had made these parts some time ago, but since I didn't have the AN nut/bolt hardware, I waited to updrill the two bolt holes. I had 3 temporary bolts in each part. To up-drill I removed one of the horizontal bolts, updrilled with a 7/32" bit, then the final 1/4" bit. I used a little cutting fluit and the cutting went very easily. Then I put a 1/4" bolt in the drilled hole, removed the second temporary bolt, and did the same up-drilling process. The drilling goes much easier, and the hole remains nice and straight, by up-drilling in 3/32" increments (something that someone on the Sonex Talk forum mentioned, and it really does work well). THAT COMPLETES SHEET W-11. I'm at 633 hrs, by the way... |
