4-14-2010 |
2.50 |
Wing attach assemblies |
- Made the second angle W11-05. I thought I had made it, but apparently made only the first one. Took about a half hour of so to make. - Used the W11-05 angles and two of the attach blocks to make the W11-02 wing attach assemblies. I already had the holes drilled in the blocks, so I clamped the to the angles with the required spacer, and used those holes as guides to drill through the angles. I'm not worried about making the 3/16" holes in the blocks larger by doing it this way, since those holes will be enlarged for tight-fit bolts later. I don't have the required bolts on hand, so the ones in the photos are temporary from the local hardware store. Spent another 1/2 hour making the parts list for the hardware I need for the assemblies on sheets W11 and W21. |
