Date:    5-6-2020
Number of Hours:    3.00
Brief Description:    R. fuel tank (assembly begins)
Finally ready to begin assembly of the R. fuel tank. Mixed my first batch of pro-seal by weight using my new digital scale. And yes.. The Pro-seal is every bit as nasty and sticky to work with as everybody says.
I masked off all around the area where the stiffeners mount Cleaned everything twice with MEK and spread the sealer on both surfaces. Fully Cleco'd the parts together and made a nice "bead" of sealer all arounf the perimeter of each stiffener.
After about an hour, i removed the masking and everything looks good.
I'll shoot the rivets tomorrow and install the fuel cap and drain.
