Date:    3-28-2019
Number of Hours:    3.50
Brief Description:    Starting elevator construction
Got the elevator skins out and removed the plastic over the rivet lines and the inside surfaces.
REading through the instructions, i see i will need a #6 screw dimple die right off the bat. So i got that oldered from Brown tools. Marked all the siffeners to be cut and got started trimming them to rough size.
