2-2-2010 |
3.60 |
Fuel Lines |
Spent the evening redoing the fuel lines in the left wing. I have decided to change the supplied fuel lines to all hard pipe aluminum with AN fittings. I did the main tank on the left wing and will be working on the aux tank on the left wing next. I need to pick up some bulckhead fittings for the wing root that I will install so that I can take the wings off if needed. |
