3-17-2007 |
1.00 |
Fuel Tank Rear Channel |
Simple part to install although there is no mention in the guide as to the location if you are installing the extended range tanks. I am installing the extended range tanks and I was able to locate them in the plans as to the location and set up but I did not receive any fuel tank channel for the additional tanks. I will need to order. |
