Had to disassemble the skeleton for the HS thismorning. I pulled it apart labeling where I thought would be appropriate so that I would be able to assemble easily. I primed all the parts ensuring a good 2 coats, sometimes 3, on all areas that will be touching other aluminum parts or where the rivets will be installed. Next I started to reassemble. Generally it came back together easily and I was able to begin riveting. Starting from the center of the rear spar and moving out to each side. some rivets on the Ribs were a little tricky and opted for the hand riveter so that I could get in close and flush. Lots of rivets. Extremely glad I invested in the pneumatic riveter. Once riveted together it is time to checkalignment one more time and fasten to the bench to get ready for the installation of the skin.
