12-31-2006 |
1.50 |
Started on HS |
Started the HS today was going well. Slowed up a bit when I laied out my rivet holes and put two rivets in an area that was to have my 7H2-6 brackets. The brackets can still go in the correct place I will just have to move the two rivetholes over. Thanks for all the great support on the Matronics Forum. I can see thatI will be using this forum quite a bit.I picked up primer and a few supplies so I will switch back over to the rudder again and try to finish that up this week. |
