6-24-2017 |
4.00 |
Trim Fin Assembly |
The trim fin corrosion proofing is dry and the final riveting of the fins to the vertical spar was done. It should be noted that the tubing was much easier to insert in to the bottom trim fin after the zinc chromate was applied. |
