Date:    5-24-2016
Number of Hours:    0.50
Brief Description:    Case apprasial continued, oil pump apprasial, rod
From VW Air-cooled rebuild guide:
-Checked listed areas for "common crack" locations, case still good.
-Determined proper measurements for oil pump and confirmed I can reuse the one I purchased with the engine.
-Dial caliper to check large end of rods, not ovaled significantly, still in spec.
