Date:    5-8-2016
Number of Hours:    1.00
Brief Description:    Evaluated engine condition #1
Evaluated condition of used VW1600cc
- thrust bearing journal pounded out
L case: min. 20.5mm
R case: min. 20.4mm
Main Journal: 55mm (i.e. standard: never line-bored)
Crank: 55mm (i.e. never turned)
Plan: (1) Thrust cut to min. 20mm or MORE; order 2mm oversize thrust bearing & cut to fit
(2) Line bore case halves
(3) Order oversize OD bearings; std. ID
(4) Order new rods?
Still need to measure crank run-out & clean case/check for cracks
